TwinTurbo.NET: Nissan 300ZX forum - FYI (for future) PTU loop = +10 more degrees of advance
evan_aggie
on March 22, 2013 at 12:21 AM
I cant remember where the CAS was at immediately after
posted by LJZTT
on March 21, 2013 at 01:28 PM
I found this out via testing quite a bit. Also, as others have said, the timing changes another 8-10 degrees when the engine reaches operating temp; i think maybe 145 or something around there.
Ok, so my timing belt is "off"...........options?
10:47:00 03/21/13
food for thought
Zvil (FL)
11:05:58 03/21/13
you didnt read the post did you? (n/m)
11:42:18 03/21/13
lol yes I did
Zvil (FL)
11:59:26 03/21/13
explain how the timing belt can drift after a fresh 120k?
12:39:01 03/21/13
Tensioner not set properly
ChrisMedaris
12:48:13 03/21/13
anything else?
12:59:08 03/21/13
you can put the belt on with all the marks lining up and
ChrisMedaris
13:02:54 03/21/13
do I remember step by step what I did and didnt do
13:23:50 03/21/13
Hi, I'm a little bit lost on this....
Medallion Man
13:02:25 03/21/13
13:28:20 03/21/13
FYI (for future) PTU loop = +10 more degrees of advance -
evan_aggie
00:21:55 03/22/13
I am aware of 5 causes to the timing drift
Zvil (FL)
13:34:50 03/21/13
then timing belt jumps should always result in timing that
18:21:54 03/21/13
skipping T-belt will only advance the timing
Zvil (FL)
20:38:14 03/21/13
then this cant be my problem
13:25:27 03/22/13
Have you removed the CAS and looked at the teeth for wear?
Woody75 (Denver)
15:44:39 03/21/13
yes, I remembered your post where you came across this
18:18:32 03/21/13
Just something to think about ...
Xteam300TT (South Tx )
22:17:57 03/21/13
*this* (n/m)
evan_aggie
10:41:39 03/22/13
car runs like absolute crap with CAs in middle
13:27:22 03/22/13
No, it won't cause damage.
TriniTT
11:30:59 03/22/13
update........
13:31:14 03/22/13
There IS only one way for the CAS to go on
Zvil (FL)
16:03:12 03/22/13
Once you check timing with a light and teeth count>>
ZUL8TR
10:09:29 03/24/13
